The mixture isn’t going to hurt it, but running out of gas will. Gas is the pump’s lubricant and coolant, so when you run out the pump can overheat and wear prematurely.
| Will engine oil mixed with gasoline ruin a car motor? | 18 | 121439 | January 15, 2020 | |
| Disposal of one gallon of gas mixed with two cycle engine oil | 13 | 39734 | October 27, 2020 | |
| Wrong gas can! | 17 | 1489 | June 11, 2012 | |
| Gas-oil mixture | 14 | 1568 | May 16, 2010 | |
| Weed whacker gas in the car | 16 | 12232 | December 25, 2012 |
