i have a 95 chevy cavalier injector is leaking how dose the injector come out?
Remove the bolts that hold the fuel rail to the intake manifold. Pry up on the fuel rail so all the injectors are removed from the intake manifold. Remove the clip that holds the injector to the fuel rail. Unplug the electrical connector from the injector. Remove the injector. When installing the new injector, apply a little petroleum jelly to the O-rings of the new injector and install into the fuel rail. Reinstall the clip. Apply petroleum jelly to the O-rings of the rest of the injectors. Center the injectors over the holes in the intake manifold and push the fuel rail down to seat the injectors. Install the fuel rail mounting bolts. Plug in the new injector.
thanks for your help
