Is it really necessary to pay $89.95 for a fuel injection cleaning from my dealer, or will a bottle of injector cleaner do the job? If the bottle of injector cleaner will work, what are the best brands?
BG 44K, that’s probably what the dealer would have used…Then Chevron “Techron” works pretty good. Add to gas when below 1/4 tank for best results…
But first, your injectors must be dirty…
Unless there’s a drivabilty problem with the vehicle, it’s not required.
Likely both will do the same thing and not using either will also do the same thing. Why do you think you need injection cleaning?
Did one of those quick oil change places tell you that?
