2002 Trailblazer the four wheel drive stopped working. Any ideas?
Push-button 4WD systems use electrical servo’s to engage and disengage the transfer case and sometimes the axles too. After checking the fuses, you crawl underneath and check the wiring connectors on the transfer case. Then you make an appointment with a trusted, skilled, mechanic…
