I have a 1991 Ford Probe That has a problem with the electronic or transmission. The car will start you can put it in gear it will run and change gears for a little while then it will stop or go into a neutral or nothing. If you stop the car and restart the car it will go into gear again for a while again.
Please help me out just need it to run a little longer my daughter needs it to go back and foward to school.
Seems like a goner. I guess you have enough fluid, but I can’t tell from here.
