I have a ford f-150 2wd pickup . A few weeks ago I had a nail in my tire on the driver’s side rear wheel. The tires and rims are Ford oem plain steel rims which I purchased from a junkyard to run a second set of tires thru the summer. When I noticed the nail in the tire I decided to replace both back tires with the factory oem rims, which came with the vehicle, while I got the tire repaired. I have ran the vehicle with these tires and rims before without incident.Soon after I put the stock rims on I heard a grinding sound from the rear of the vehicle. I assumed that my rear disk brake pads had worn away.I put the car up on jackstands and inspected the rear brakes. I have approx. 1/4 inch of lining material on the pads,what I noticed suprised me. The tab on the outer brake pad that sits above the caliper had some material on it. I turned my attention to the stock factory rim and I saw a ring where the brake pad tab had rubbed the inside of the rim. My short term solution was to get the other tire fixed and put it on . I have had no problems since.What is going on? The pads are not worn badly and if I were to replace them ,the metal backing on the pad would protrude farther out and make more contact with the rim. Is there a problem with the trucks rearend?I can detect no movement in and out with the truck on stands so I think the c-clips should be ok.This truck has traction lock (fords version of posi traction). Could this be getting ready to go bad?Is this a common problem with an otherwise dependable ,trouble free vehicle?
Related topics
| Replacing Ford truck brakes way too often | 14 | 1456 | August 15, 2007 | |
| My f150 eats brakes/rotors | 10 | 3723 | March 19, 2012 | |
| Ford F150 Brakes | 11 | 4457 | May 6, 2008 | |
| Clicking tire | 3 | 1260 | August 9, 2014 | |
| Brake noise | 0 | 289 | October 22, 2009 |
