Ford F-150 with 4.2 V6
The V6 is an older OHV technology engine where the 4.6 is a more modern design. If you are not carrying a load all the time and drive mostly on flat ground, it will be OK. If its a good deal, get it checked out by a mechanic and if all is well, then consider getting it.
