Ford Explorer XLT
Sometimes, In the morning, my battery will be low or completely dead. Once I jump start it runs fine and will start up no problem. I’ve replaced the battery several times and had the charging system checked, but they could find no problem. HELP!!
On the red bar above the questions, click on SEARCH. In the inquiry block, put BATTERY CHARGE. A number of questions and responses will be revealed on your problem. Go there and read those. If you have further questions, or comments, come back and make them.[u]
You need to check for a current drain in the electrical system then.
Disconnect the negative battery cable and connect a test light between the battery terminal and the cable end.
If the light is illuminated brightly then you have a current draw.
You then have to remove fuses, disconnect the alternator, etc. until the light goes out to determine what circuit the problem is in.
