I have a 2001 Camry 4cyl automatic with 53k. I just changed all the fluids (trans, differential, brake, coolant, power steering) at 36k (April 2010). I change the oil every 3333 (3 times every 10k). Tires are nearly new.
I am going on a long trip next week and plan to change the oil before I go. Should I change any other fluids? They all look fine and do not leak or burn, but the car was senior-citizen owned before I bought it and its maintenance history is unknown.
I agree with all of the above. Your fluids are fine as-is. If you insist on doing something for your car in preparation for your trip, check the wiper blades. Otherwise, you’re in fine shape. Off you go.
Is your timing belt 10 years old? It doesn’t look like you have an interference engine, so you can decide whether you want to have it changed out or not.
I agree with Whitey and the others. Goldwing brought up a good point that you should check (even without an interference engine, a busted timing belt will leave you stranded).
Am I missing something that the others see? You put about 5000 miles on the car each year. At 3000 miles, you change oil every 9 months or so. I don’t think that you are overly conservative on oil replacement, but you may have waitied a bit too long for the other fluids if this was the first time they were changed. I agree with the recommendations for transmission and brake fluid changes, and that would mean that you should do it more often.
jt, he put 17k on since April 2010. (S)He is not the original owner so I’m guessing that is when (s)he bought the car. I think (s)he is being a little too conservative, but then, if something goes wrong, I’m not the one stuck with the repair bill.
