Firing order - 2012 Hyundai Equus
What is the firing Order and cinders of the
Equus 2012
It has coil-on plug ignition. Plug the wires in that reach.
Why do you need to know the firing order?
Sorry not the firing order . But which cylinder was 7,6,5,2
If you are working on the car yourself, you need a repair manual. Try here.
https://www.factory-manuals.com/expand-hyundai-equus-2011-2012-2013-2014-2015-2016-factory-repair-manual-450.html
I can’t find the cylinder numbers on the internet.
You don’t say, but I am guessing you have some sort of generic code reader that is telling you there is a misfire in cylinders 7,6,5 and 2 and you want to change the coils on those cylinders, right? 4 of 8 cylinders are mis-firing, it is pretty unlikely 4 coils failed at the same time. Sparkplugs, maybe, replace all 8 first and see how it goes.
Unless you just want to toss parts at the problem, you need the manual with trouble-shooting trees included.
Hey thanks on manual yes got
Miss fire on three . Put new plugs in at $30 x 8
Cylinders 1,3,5 and 7 are on the passenger (right) side, cylinder #1 is in the front.
Cylinders 2,4,6,8 are on the drivers (left) side.
