Fault Codes for '02 VW Passat
In a previous post (http://act…48399.page) had noted my initial symptoms that my V6 Passat has sounding like a diesel - although it is not! The sound is definitely under the hood - possibly the engine. It’s a steady sound that’s gotten progressively worse! I had the VAG-COM connected at Joe’s VW shop in Dedham, MA (GREAT GUY!) and the faults I got were:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4 Misfire Detected
P0304 - 35-10 - - - Intermittent
16687 - Cylinder 3 Misfire Detected
P0303 - 35-10 - - - Intermittent
16690 - Cylinder 6 Misfire Detected
P0306 - 35-10 - - - Intermittent
16891 - Idle Control System RPM Higher than Expected.
P0507 - 35-10 - - - Intermittent
Any thoughts or ideas what this could mean!?!
What was the last thing that was done to the car before the misfires started?
Did you have a tune up done?
Since the codes aren’t from a common bank of cylinders, the first thing I would do would be to pull off the ignition coil sticks and spark plugs, take a look at their condition, then snap everything back together tightly, and see if the misfire issue vanishes.
If it does persist, then I would swap those three coil sticks with the other three cylinders, and see if the problems follow the coil sticks, or stay put. That would then lead to further choices.
BC.
