I have a 20-year old 1.8l Digifant-injected, manual transmission Jetta that has started to idle at 3,000 RPM (once it has warmed up). I’ve looked through the manual and poked and prodded at various things. I think I’ve ruled out the PCV valve, the idle position screw, the idle stabilizer valve, and the temp sensors; I’ve swapped or disconnected them with no effect. If I do disconnect the blue temp sensor, the idle drops to 1,500 or so. It doesn’t hunt or surge, just sits steady, and has no effect on the driveability. I’m not a “mechanic”, but I have changed its oil, brake pads and rotors, radiator, clutch cable and various belts and hoses, so I can handle a wrench and screwdriver. The car doesn’t owe me a cent at this point, but I’d like to solve this without taking it to a garage, if I can. Thanks for any help!
Related topics
| Why is my car idling so high at start up | 6 | 24322 | November 30, 2010 | |
| Cold stutter | 3 | 515 | April 8, 2010 | |
| 2013 Jetta – Mysterious stalling | 7 | 9618 | September 4, 2021 | |
| Early 90's Corolla has increased idle speed for some reason | 19 | 17373 | November 10, 2013 | |
| 01 Jetta 1.8T - Stalls at stops | 3 | 3389 | September 12, 2007 |
