This is not a “collectible” car. Therefore it has little value. If it runs you could get $500 to $1000 for it depending on how well it runs.
Getting it running after 10 years of sitting is likely to cost more than you would get back from the sale of the car. The tires aren’t safe anymore due to age. All the fluids should be changed, there could be leaks from dry seals. New battery, and then there is dealing with the 10 year old untreated gas in the gas tank.
To attempt to get it running first requires a new battery. The next order of business is draining all the old gas and disposing of it. Put in about 3 gallons of fresh fuel and see if the car will start and run. Make sure there is still coolant in the motor and radiator. Try to start the car. If it runs and after a few minutes settles into a decent idle you might just have a saleable car. If so, clean it up, wash and wax it, take out all the personal effects, vacuum the interior, take pictures and put it up for sale on Craigslist and/or ebay.
If it won’t run your best option is donate it or call a salvage yard to tow it away. You could contact your local high school or vocational tech school. The auto shop teacher might enjoy this as a project for the students.
