Is this possible? Its a 99 Corolla with original struts and springs. Its a rotational whining, scraping noise best heard when turning right and when suspension is bounces up and down.The noise is transferred inside the cabin and seems to be coming from the front passenger side.What do you think it might be?
Wheel bearing?
You got it! it was the front passenger side wheel bearing going bad. Wheel had a lot of play and was causing the growling and grinding noise heard in the cabin.
Good going. Thanks for letting us know your happy outcome!
