Had issues with an evap. Replaced the tank. Then had problems with the fuel lines after replacement. The self repair to the tank seal/fuel pump hanger had blown out or upon install the seal had not properly sealed. Several codes came up. Cleared the computer.
I am want to know if anybody is aware how long it takes for the computer to set up.
I had several codes. I had a P1171, P0440, P0137, P0157, P0452. Prior to resetting the computer I had all kinds of problems. I had back firing and hesitation upon acceleration. I had air in the line due to the replacement of the tank. I had a problem with the air seal on the tank.
I have driven several miles and no codes have come back on. No check engine light. Can I assume that every thing is okay.
What I am asking if those issues were real problems would they have come back immediately upon starting and driving several miles. All those codes could be accountable due to the issues with the tank replacement.
I appreciate the help. I don’t want to go back to AutoZone to have them check. They got issues.
199 Isuzu Trooper 3.5l
Thanks
