Thanks for the tip, George. The first thing the mechanic recommended was to have a fuel system service done (hooked it up to some machine and cleaned throttle, intake, air flow injector, etc.). Paid him $130 for the service. Do you think the fuel injector cleaner might still make a difference? If you do, then I’ll try it. But just wanted to point out that I’d already had that service done. Thanks.
Edit: OP, have you tried the experiment slowing down, foot off the gas pedal, from 35 mph to 5 mph, when approaching a stop sign in 3rd gear, try to determine if you can feel the injectors turning back on again as you approach the stop?
No, I haven’t. But I have slowed down and haven’t felt anything. But then, when I touch the brake, there’s sometimes a slight jerk, which could be a separate, brake-related issue. I’m going out in a minute and I will try this 35 to 5 thing and see if I notice anything. I’ll put it into L when doing it, since you say I should use a fixed gear.
BTW, when baking out of my spot yesterday (which is when the problem usually manifests), when I came to a stop after going in Reverse, and was about to put it into Drive to go forward, the engine died. This has happened before a few times, though it’s not frequent. So definitely a fuel flow issue from somewhere.
