Engine won’t turn over, stuck in drive on computer when shifted in different gear
Hi, was driving to a friends and after filling up I went to drive, accidently bumped the shifter into park. The car started rolling, computer on the dashboard says it’s in “Drive” when it’s in park.
Key refused to come out. I got into the “shifter solenoid lockout” next to the shifter after a quick google search and was able to pull the key out of the ignition.
Fried my battery after trying to jump it when I had to sit in it for 8 hours waiting ina friend to pick me up. Got a new battery, connected it, dashboard is still the same.
I can now get it into park/neutral/all other shifts and those work but now the engine won’t start. Everything comes on, dash lights, headlights, radio, but NO ENGINE. Going to have someone look at it when I can, currently it’s stuck out in the middle in the desert until I can figure out somewhere to tow that isn’t gonna cost 400 bucks with the limited companies in the area. Is this a computer glitch or did I completely mess up my tranny with a simple bump? At a loss. Any help is appreciated.
2012 Honda Insight
Honestly most 2005+ vehicles have a sensor that help’s to not damage the transmission when you " accidentally " shift your gears while drive! However older vehicle’s didn’t have this technology so once you shifted gears while drive, your vehicle would take a long vacation with the mechanic!
Well that’s a relief to hear! Hopefully it’s fixable, it’s a wonderful car that I had to truly save for so here’s hoping.
Any check engine code on your dashboard after the incident?
Try shifting into neutral and then see if the engine starts.
Update, it was the shift cable that broke! Had it repaired at a local shop. Thanks for the help!
Update for you, it was the shift cable that broke! Had it repaired at a local shop. What a weird small fix. Thanks for the help!
