How about a engine swap
Pull 3.0
Set in 3.4
Would the 3.4 bolt right up?
What about wiring?
Thanks
Pull 3.0
Set in 3.4
What about wiring?
Thanks
Oops
93 Toyota 4runner
Auto
This is a swap that has been around for about a decade, the motor and the transmission might bolt in (you might have to update the mounts) and the ECU and wiring for the motor needs to come with the 3.4 but the Body harness will not swap over, a conversion harness is $700 for the Automatic (google search turns up lots of discussions) It’s been done many times before apparently
Getting it smog legal may be a problem
They dropped the smog law here a couple years ago.
im not spending 700 on wiring
