Hi all, please help me diagnose the issue with my 2011 Nissan Altima Coupe. Mileage - 148318. Was driving home and started accelerating from braking (red light changed to green) and then the engine started shaking the rest of the drive home with the RPM fluctuating +/- 1 of where it should be based on speed. Shaking lessened when slowly accelerating but constant at even speed and idle.
Maintenance History:
At 144738 miles
Throttle body fixed (had crack), PVC hose replaced with correct hose
Recommended but didn’t perform: Complete fuel service, Replace power steering fluid, Replace spark plugs
No thus far I have not done my own work but with the amount of money maintenance has cost so far, I’m looking to solve this issue myself if possible. The check engine light is not on. If you watch the video linked to about 50 seconds in it shows the dashboard with the RPM fluctuating and no check engine light
Many possibilities needs a good diagnostic workup. But my guess is a problem with unmetered air getting into engine. Check intake air path, vacuum system, and pcv system to begin
