RE: FORD PROBE GL (non-turbo)
Last week suddenly car wouldn’t start Thurs. night. Cranked but would not turn over. Heard click at ignition switch area when key turned to start position. (Although I could only hear one click from inside the vehicle with windows shut, I was told that clicks audible under the hood from standing outside.) Tried jump starting (from a good battery using proper connections) unsuccessfully, repeated tries several minutes apart, allowing longer and longer time to charge.
About every third attempt, instead of cranking sounds, I would get silence, with only the click audible.
Temperatures decreased from approximately 50s to 20s when symptoms began.Battery is old but tests good/replace soon: 330+ CCA at 43 degrees, original rating CCA 530 (silver battery now at 7 years. Will replace, but garage did not have required size 56). At that point, the amps gauge read at the low end of the normal range (and today it read mid-way in the normal range).
Had car towed to garage on Friday. Mechanic looked at on Saturday and decided it was the inertia switch, which he said had “tripped”.
I watched video for technicians on inertia switch but it shows on newer Fords. Mine is not located at the kick panel and does not have a red button on top. I am not certain from my experience whether the reset button would actually be in a different position when tripped or he merely surmised that is what had happened, despite my telling the shop manager that I had not so much as bumped a curb. Also, the trunk was not slammed or even opened prior to the car not starting.
Car presumably started fine at mechanic when they pulled it into the garage to put air in tires and back out to the lot, as well as when I started it to drive home on Sunday. However, on Tuesday it would not start. Just in case, I depressed inertia switch reset and tried cranking again several times, giving it some gas, until I was actually pumping it vigorously in desperation as a last resort (several seconds turning key each time), and on about the 5th try, the engine began to catch just as I was releasing the key. Reset the inertia switch one more time (just in case), and after a couple more attempts, it finally started, but when I was going in reverse to back out and then putting in gear to start out in first gear, for about 15 seconds total, I heard a bizarre loud, fairly high-pitched whistle/whine type of sound that seemed to come from under the hood coming through the central area of the dash where the radio is located.
Drove about 5 miles to my job, and about 2 hours later was able to start the car on the first try.
Lately usually driven relatively short distances of 2-4 miles, with a longer drive of 11 miles broken up into 6 miles + 5 miles on the return trip the night before this started happening.
Need to call garage in the morning but in the meantime hoping for some professional and/or experienced opinions on what is going on(?)
Thank you so much for any input.
