2003 Subaru Baja, it has a slite hesitation when accelerating normally from dead stop, It also happens when backing off the accelerator, and then depressing the accelerator. Does this car have points and condenser.
No. It has ignition module/coil ignition system.
Is the check engine light illuminated?
The check engine light does not work.
That in itself is a problem. I think you need to take it to a shop for a proper diagnosis.
Thank you.
By the way, did you know the founder of AAMCO was named Bob Morgan? Lousy chain, nice guy
