Engin dies
While driving down the road the car on occasion just quits without any warning. After a few minutes it starts back up again but scary in traffic
check the ground wire from your battery, both ends.I had an olds intrigue I had to change the ground from the fender to rhe engine.
As Oldschool says, it’s possible that the ground (negative) cable from the battery to the fender has an intermittent connection problem. Also, ignition switches, at times, show this behavior.
