Electrical system
I HAVE SEVERAL DEVICES THAT WORK FROM A RECHARGEBLE BATTERY. EACH ONE FAS IT’S OWN CHARGER. I CAN BUY AN ADAPTER TO RECHARGE FROM POWER OUTLET IN THE CAR. THESE ADAPTERS COST AS MUCH AS $75.00 EACH. I GOT AN ADAPTER TO CHANGE CARS VOLTAGE TO 120, AND THEN PLUG IN THE CHARGER. THIS SEEMS TO WORK. CAN I USE THIS SAME SYSTEM IN THE THE CARS IN ENGLAND?
It ought to work. Cars are 12 volts the world around.
PS: please turn your capslock off!
I don’t recall if England still has positive ground cars, but you might want to check that out and if so check out to make sure the charger will function properly with the change in polarity.
Yes it will work. British cars changed to negative ground years ago.
