have an 05 cavalier timing chain is noisy,
 98k miles check engine light on intermittent. anyone having simalar problem
Have you had the codes checked?
code reads intermittent miss vaccum at idle low
You might have more than one problem. A noisy timing chain is your lucky indicator that it might break. Verify this with your mechanic and beat the internal engine crash blues.
