Hello,
   I have a 1998 jeep grand cherokee limited. The door doesn’t want to close fully any more. Use to the door would shift upward right before it closed. It doesn’t do this any more.
 Is there a way to adjust this?
I don’t believe there is any ajustment on the door. The hinge pin bushings are wore out. These are pretty easy to change if you have some help to hold up the door. It should shut like new. I’ve done this to two of my vehicles.
