Getting a fault code P0325 (Knock Sensor Circuit Malfunction). I plan to DIY repair.
How can I test the sensor itself? I know I can check harness resistance for an open/short, but wanted to know if there was a way to check the sensor itself. Before I make a purchase, I would like to know if I only need a sensor, a harness or both. Also, any tips from those that have had experience with this issue, please feel free to offer suggestions/advice. Thanks.
Good advice above, definitely the place to start. The knock sensor produces a small voltage when it gets vibrated. The bigger the vibration, the bigger the voltage It doesn’t need a battery to work, it produces the voltage itself from the energy of the vibration. The voltage also varies w/ time in different ways depending on the nature of the vibration motion. Be aware that it is possible for a faulty sensor to still respond with a measured voltage output when you whack it. It might just not produce the correct voltage is all, too high, or too low, or vary the wrong way w/time compared to the spec the ECM is expecting. So to have a reasonable chance to successfully test one on the bench you really need to have a known good one to compare it to.
