The buildup is on the neck of the valves preventing the
full retraction of the valve on each cycle, leaving a
slight slack at the top when the rocker arm is already
coming back down. tick-tick-tick-tick.
While I can picture what you’re describing, if that is indeed what is happening, why isn’t it quickly causing a burned valve?
