I replaced my 2000 Pontiac Montana driver-side CV axle just fine…tapped the inner CV joint housing at the groove with a large screwdriver. The new passenger-side CV axle, however, refuses to go in. The splines are aligned, but when the retaining ring hits the bevel at the female splines, the assembly stops sliding in. I know I can’t beat on the end of the axle assembly, and since there’s no groove in the passenger-side inner CV housing, I clamped a chain ViseGrip around the housing to give me something to tap on. How hard can you beat that thing to get the retainer ring to compress that last little bit?
Related topics
| CV axle carrier bearing cant get all the way into carrier | 13 | 2778 | December 10, 2021 | |
| 95dodge van cv replaced cant get baljoin back in help! | 12 | 1089 | March 13, 2009 | |
| Can't get half shafts to go back in | 2 | 695 | May 22, 2018 | |
| Last minute CV axle post | 16 | 5372 | July 8, 2016 | |
| Cv axle installed wrong? PLEASE HELP | 16 | 38476 | September 24, 2021 |
