2005 Jeep Wrangler. will cm restrict the amount of air pulled by the radiator fan to cool the engine?
How is the trans fluid changed?
Automatic or manual transmission?
No way I know of.
A cracked manifold has no effect on the amount of air moving through the radiator.
Changing the transmission fluid depends on the type of transmission. Is your manual or automatic?
Hi; automatic. I use it as a mail car. The drive is easy but it’s constantly overheating. There’s no problem if I remove the hood. So, i’ve had louvers punched into it. Still, it overheats.
What problems will a cracked man cause? Also, upon first start up I hear a stinging like noise coming from the drivers side of the engine & also a noise from the same area almost like a click-clack… no pun intended
