could you tell me how to remove vent window on 66 mustung
That’s getting pretty specific. Unless someone here has one, we probably can’t help you much. The shop manual for your car would tell you - it’s a good investment.
Remove the inner door panel. Roll the window down. Remove the two bolts that secure the vent window/frame to the door. Remove the vent window/frame.
I believe that the window channel and vent window frame come out as a unit. Don’t they Tester?
Thats what he said
Please excuse me, Peacefrog…
Or do you mean remove the vent glass from the frame? That takes a specific tool if you dont want to damage it.
You have to drill out the rivet at the upper hinge. If I remember right, you just pull it up from there. A new vent window comes with a frame and you have to flair the new hinge. That is how someone broke into my 66 Ford.
thank you very much !!
