does my rubber sleeved bushing press out of the control arm as easy as the metal version? i inspected my control arm and think the front bushing is causing a metal clicking sound. is it due to the metal sleeve or wear on the thru mounting bolt? do you replace the bolt when you replace the bushing? sometimes?
thought clicking was from large alum bushing but it is from smaller front bushing
yes, the 2 bushings cost more than a new control arm
Almost ordered alum bushing. Till I got in there with pry bar after I had loosened the bolts for it. Click comes from front bushing. But I did not take off arm to inspect bolt. Checking arm is a pita.
