I have actually put in a secondary fuel filter in-line just before the fuel pump. It is the ind that is cylindrical, ape 2 inches in diameter, and I chose the one with the transparent housing so I can see the fuel. The only think I notice in that is the fuel turns kind of orange-ish after not having run for a week or more. Either that is the normal color of gasoline when it is aging, or the filter is capturing some of the small rust particles, and when the car is shut off, some of those come off of the filter material and become resuspended in the gas in the filter. Either way, I’ll change that out soon too. My purpose was to have that to monitor the condition of the fuel coming through the fuel lines from the tank and to the carb. Once it seems as if all of this gunk has worked its way through the system, I’ll pull that off and replace the hose with a new style fuel hose (better rubber than the stock grade).
I picked up some very good, thick, 100% copper couplings to put on to the ends of the wires. I have done this for the 2 ends of the wires going onto the horn relay (the 8GA wire coming off the alternator, and the new 6GA wire I will connect to the battery (+) terminal. The guy at the store accidentally cut 6GA wire for one of the segments I asked for (wanted 2 different colored insulation), so now I have a super wire going to the battery. The mulitmeter reads 0.1 ohms from the BAT terminal on the alternator to the end of this wire (on the other side of the horn relay; I am measuring total resistance through the wires going from the alternator, through the horn relay and on to the battery). This is as good as the resistance just going through the wires themselves, so the connections are very good.
I need to get a second coupler to connect this 6GA wire to the (+) battery terminal, as I have decided to hook it up a bit differently than I originally planned. This should eliminate all wiring problems in this circuit (I hope).
It’ll be a couple more days before I am ready to fire it up again, so I’ll relay (pun intended) the results to the group at that time.
Have a good evening
Cryoman
