OK. When I started it this morning, at high idle (cold engine) the voltage across the battery terminals read 31.41V. Engine off, battery reads 12.3.
I put the (+) probe of my multimeter on the BAT terminal of the alternator, the (-) probe on the positive battery terminal. The meter would often read erratically, as if the voltage was not stable, but it was common for it to read appx 1.56 - 1.59.
The GEN light was OFF under this idle speed.
Now, when the engine warmed, and the idle dropped to normal speed, the GEN light came on.
Battery still read 13.7 with engine running. The BAT terminal on alternator to (+) battery terminal reading was still a bit erratic, but it was more common for it to stabilize around 1.1 V.
Here’s the interesting thing…with the lights on, I can see when the ALT output is strong enough to cause the GEN light to go off, because the headlights brighten. Under these conditions, I pushed on the wiring plug going into the voltage regulator, and I could see the headlights brighten and dim, particularly with the top wire, which I think is the main current input. At one point, the headlights remained bright and the GEN light shut off. Unfortunately, I didn’t re-take the measurement between the alternator and battery before shutting off the engine (stupid). I then re-started the car and couldn’t reproduce the condition where the GEN light is off and the headlights are bright (at slow idle).
So, next thing I am going to do is to work with the wiring connected to the V regulator to make sure they are functioning. I can still see the headlights brighten a bit when playing with the top wire, but I can’t get the unit to work as it should by just tinkering.
I’ll post more information as it becomes available.
Any thoughts on these observations would be helpful.
Thanks so much.
Cryoman
Just FYI - 6.6L 400 CI engine. The 455’s weren’t available in 1968 except in the Hurst Olds configuration (and apparently if one knew how to work the system when ordering).
Best wishes.
