Clutch
I have a 1994 Mustang 5.0. after changing my clutch it grains when trying to shift to 2nd gear? the quadrant has been replace. any one with any info on what is going on please help
I owned a 5.0 in another life-an 89 to be exact. When you replaced the clutch did you also replace the steel bearing retainer as well as the throwout bearing and clutch cable? If not, there’s your problem. Having a working quadrant doesn’t help much if nothing works below ya know.
