I drive a 2004 Kia spectra (base model) w/ 93k
My clutch would start out fine as I start the car, but after pressing on the clutch pedal for about 40-60 times on one trip, it’ll start to loose pressure & becomes stickier. And as I press on the clutch pedal more & more, the problem gets progressively worse to the point where I have to manually pull the clutch back up with the tip of my foot.
I also notice that when I drive with the air conditioning, the problem would precipitate earlier & clutch response deteriorates much quicker.
But when I let the car rest for a couple of hours or overnight, the clutch response would slowly return, and eventually be normal again.
I’m scared this problem will get worse in the future & possibly cause an accident.
Please help & thanks in advance!
