Clutch chatter in first gear
hello guys!
i have a toyota yaris 2006 1.4 diesel and i changed the clutch about 10 months ago.it has like 1 month that the clutch starts chattering when the car gets hot.like if you frive in the traffic in the city for about 1 hour the car starts shaking when i pull from a stop in first gear.the clutch is new so i dont know what is the problem.
Thanks for your replies in advance
Was the fly wheel machined or replaced?
the whole clutch kit was replaced
Did you use a thread locker on the flywheel to crankshaft bolts and on the pressure plate to the flywheel bolts?
im sorry i didnt replace it myself
i went to a mechanic and i dont know how he installed it
Most clutch kits don’t include a new flywheel. But if you didn’t install it, why are you asking here? Have you brought it back to the shop that did it?
(The questions are about the flywheel because problems with it are the main reasons for clutch chatter on take-off).
Then take it back to whoever did the clutch replacement, because it’s going to have to come apart again to see what’s going on.
You can get clutch kits with flywheels.
Depends on how much you want to spend.
https://www.google.com/search?client=firefox-b-1-d&sca_esv=ae093cb415ffb20d&q=clutch+kit+with+flywheel&udm=28&fbs=AEQNm0BglSNKPbDQcL4Et01QEIYvJ5VGsHgUL_tsKqYywhWXkknveTpaLEIQiU02u5i1FK5Aui8Lbcs6UtNG0K_ZRX5_Sfaez_nbio7ZevU-01UapLHdMxJwfMvS9kwCdcBWZIgyetQbYTQxEyNA7fx0TazpAB8FAg5vSqa7RcEA052q-QwUu2HV1exHBcZZpyhUwkJXIsYJxAypdjNo_m_hWWBLc0ktRw&ved=1t:220175&ictx=111&biw=1366&bih=607&dpr=1
ok thanks guys
