The science of the issue is in what is known as an anode. If water remains in the clear coat finish when a car is waxed, the water is captured. The captured water then becomes heated by the sun by much the same method that sun heats through a glass window. But since the water is captured it can?t evaporate or get hot enough to rise above the wax. Thus the water remains and without evaporating, creates an anode (oxidation reaction) effect towards the paint. When this occurs enough times the water eventually makes way to the bare metal. The corrosion is minute, but eventually will show up. This will never happen if a car is fully dried before waxing.
The coating before clear coat was a different composition lacquer I believe. The coating and paint would eventually dull and crack. Clear coat resists cracking but will certainly scratch. Clear coat can also have UV protection in it.
Waxing in itself will not hurt clear coat, but moisture under the wax will create the anode effect.
It would take several years for the corrosion to show due to the minute amounts of moisture trapped under the wax.
The entire point is that waxing, although looking nice, can be detrimental over time if done improperly.
There is not Car Company or Oil Company on the planet willing to divulge any of this information, they’ll never do that. The NASA point was to teach the effects of small amounts of moisture against a seemingly protected surface for corrosion awareness. The same video revealed that BTG (Boat trailer grease) was well suited to grease any axle during that period because it would virtually not break down. The entire military uses the stuff today, but is marketed differently to them.
On our entire planet we are all caught up in paradigms. If a theory or explanation does not fit our understanding we tend to dismiss it or ridicule it. Unfortunately some grade school habits hang on throughout our lives.
Of course the entire waxing thing sounds ridiculous, but the science of it remains factual and can’t be dismissed with rational, but scientific experimentation, which was performed in the video.
And about the paradigms and how they apply…well
–Man couldn’t fly—until Wilbur and Orville
–The world was flat—until Columbus
–Gravity was unknown—until Sir Isaac Newton
?Just because we have never been exposed to information doesn’t mean it isn’t true. How we respond to that information, on a global basis, is where the fate of all humanity lies. ?
I’m not referring to the wax, but rather to paradigms.
