im trying 2 buy some spark plugs but dont know which ones the engen has a code its …NGK BCP6E 11… thanks
Ok, I’m going to help you here and translate your post to what I think you’re trying to say:
“I’m unsure which spark plugs to buy for my Civic. The engine indicates a code or part number for the spark plugs, which is NGK BCP6E-11. Thanks.”
If this is what you meant, then it’s safe to say that you need a set of NGK BCP6E-11 spark plugs if you want the plugs that Honda recommends for this engine. Any parts store should be able to help you out.
The owners manual states which plug too.
