Chrysler Rev Issue
My 05 Chrysler Town and Country LX with a 3.3 v6 won’t rev past 2500 rpm, i’ve read the codes from the obd2 port and the code is P0016 which is cam/crank sensor correlation issue, but i’ve replaced both sensors and i still have the same problem, how can i fix this issue?
Replace the timing chain set.
Are you sure this would fix the issue?
Inspect the flex plate between the crankshaft and torque convertor. If the center cracks in the flex plate, the cam and crank signal correlation can be off by 10 to 20 degrees.
