Check Engine Light, High Manifold pressure says Jiffy Lube
Sad but true. Had a neighbor’s car with a cracked cylinder head because JF did not know enough to bleed the air from the cooling system when refilling it after a flush.
Taking a car to Jiffy Lube is like taking your wife’s heirloom wedding ring to Kmart to be cleaned by the person who changes batteries in Timex watches.
