i got a 2000 celica GTS 4 speed auto, wondering if anyone knows the amount of work involved in converting it into a manual if its possible at all, thanks for replying
All things are possible with enough $$$ ??? ???.
It is not worth the cost. It involves more than just a transmission as it would on a 61 Ford. Today it means all kinds of changes. Likely the computer controlling the engine will need to be changed for example.
true enough but your point may be the extact opposite, for instance logic tells me that all celicas are the same chassis,cable and wire linkage spacing etc, i could be totaly wrong and i’ve had one heck of a time finding celica specs as its a discontinued car
