Carb's fuel bowl losing fuel, evaporating
Now the Corolla is back on the road and my daily driver, my prior daily driver 50 year old V8 Ford Truck isn’t getting nearly the amount of use. It runs good, but after it sits unused for 5-7 days the fuel in the fuel bowl is presumably evaporating and doesn’t have enough fuel remaining for the engine to immediately start-up. First I have to crank the engine for a few times to fill the fuel bowl, annoying. I got to wondering if maybe there’s a simple solution to this? Spraying a dose of starter spray into the air intake? What if I installed an electric fuel pump with a switch so I pump fuel into the carburetor bowl w/out running the engine? Even simpler if there was a manual fuel pump available for this, using a rubber bulb I’d press a few times to prime the carb?
Why not just pump the gas pedal to get gas into the carb.
pumping the pedal activates the carb’s accel pump which transfers gas from the fuel bowl to the air-intake, won’t work if the fuel bowl is empty. I generally do that b/c it does help if the fuel bowl has a least some gas remaining.
Another idea, I have on occasion popped the top off the carb and filled the fuel bowl directly from a fuel-container. Maybe there’s a way to do that without needing to pop to top off the carb? Removing the top of the carb is a fiddly, awkward job.
You asked this same question back in 2021.
I didn’t realize there’s rule here that a question can only be asked once every 3 years. Hopefully there is no such rule. In any event, still looking for a practical solution. As I recall that particular problem turned out to be the fuel bowl was not vented correctly, getting pressurized from the engine heat, and gas was being pushed out of the fuel bowl into the throttle valve area.
No rule against it, but it might be more productive to revive the old thread instead of starting a new one.
Two different questions, not the same topic.
Just curious, are you sure it is evaporating and not draining slowly back to the tank? a gas cap going bad can cause flow back. If you have a separate in-line
gas filter see if that is empty too.
The carb float bowl is porous and leaking.
I would check to see if it is leaking out the bottom due to a plug that needs resealing or
A crack in the housing. This would happen with my 59 Pontiac. Never found a solution except rapidly pumping the gas. Sold it about 1971 so memory is foggy. Tried dumping a little gas in the carb once, backfired and started a fire so not recommended. I’m sure the apartment got dinged for an empty extinguisher.
Fuel bowl empty vs fuel bowl empty
Yep, totally different
I don’t think it is possible for fuel in the fuel bowl to drain back to the tank via the carb’s inlet, it would have to go uphill.
How is that simpler, easier, or faster than just cranking the engine for an additional 5 seconds?
Well, they do sound the same … lol . but if you read the 2021 OP, the clue was the throttle plates were covered with fuel. Not the case for the today’s question, throttle plates dry. & Last summer I removed the carb for another reason, and while it was removed, as a leak test, I filled the fuel bowl and placed the carb over a container over-night to see if any fuel was leaking out. None. The explanation for the empty fuel bowl seems like it pretty much has to be evaporation…
I concur it is simple enough just to crank the engine longer. But it is more than 5 seconds longer. The downside of longer cranking is it runs down the battery, overheats the starter motor.
Usually the accelerator pump diaphram gets old and cracks, draining the fuel. If you try to start it after one day and it’s empty then that could be the problem. I had to replace that thing twice in seven years. Tomco kit.
2 days vs 7 days, that’s 5 more days for evaporation.
Install one of these back at the tank:
This is what old car restorer’s do to eliminate this problem and vapor lock
Now we’re getting somewhere! Thanks!
