Hi guys. I was trying to repair a scratch and after wet sanding it I see a patch appeared. I think I might of over sanded my scratch with the 3000 grit sand paper. (I was using my hand directly, not with a block) But I’m not sure. Does someone know how to fix this?
Please help, thank you!
You sanded through the clear. You need to re-spray the clearcoat. There are internet sources for spray cans of the proper clear as well as liquids that can be sprayed with a paint gun.
Looks like the scratches went through the clear coat and it is peeling.
What about these other marks? Looks like a rough bumper cover.
Yeah sometimes you just need to know when to stop. You use the high grit paper to remove dust nibs, over spray, or orange peel. Then you polish with compound. once you expose the color coat underneath the repair will always show. As suggested, the quick answer is just to spray a few coats off clear on top for protection, sand the overspray, and polish. Might be time though to order some matching color and clear and re paint the entire section. Trying to level a deep scratch with clear is easier said than done though.
Okay thank you!
Yeah thank you. I didn’t expect it to be so hard, I was following some YouTube videos , and the scratch just wasn’t disappearing even after sanding. I think I misjudged it as a clear coat scratch. And after sanding the patch appeared ![]()
Therefore order two or three cans of color and the same clear from and do the whole dang bumper. Cost will be around $100 and a month wait but the match will be perfect. Our friends from automotive touch up.Com agree.
It’s not “hard” so much as it is time consuming. You seem to be on the right path. Suggest to just take your time. If it takes 6 week or 6 months to complete the job, that’s how long it takes.
You can do the whole job on a Saturday, but if you don’t know how to use a spray can, go buy a couple cheap spray cans from the farm store and practice getting no runs on a wheel barrow or something.
Yeah I actually bought the paint already. They come in primer, paint and clear coat. I bought it in paint form instead of spray as I thought it would be easier to work with
I worked on a part of the scratch yesterday and applied primer. I wasn’t sure how long I need to let the primer rest, I searched online and it said a day.
Okay thank you! It definitely is time consuming!
I think we are missing something in the translation. Did you buy the little touch up bottles with a brush in them, or did you get a pint of automotive paint mixed and the proper reducer, hardener, etc? If just a spot, no big deal, but you can’t do the whole bumper with a brush. That’s why you just get the spray cans if you don’t have a spray gun etc. if you just plan to touch up all the spots, fine, but if you want a new looking bumper, gonna need to spray it.
I agree, those white areas look like paint transfer. Commercial products designed to remove paint scuffs would be my first attempt or actually, something more generic like mineral spirits. Make sure the area is clean and dry first. You don’t want to scratch the paint because there was dirt on the paint before you started rubbing it with mineral spirits…
