Vehicle:
2005 Five Hundred (220,000 miles)
Symptom:
Car surges (lurches or RPM shoots up to 1500-2000) when outside temperature is 75+ F and ONLY when A/C is on. In addition, when outside temp 80+F, A/C occasionally not as cool, and engine temp goes to HOT (nearly overheating. Shutting off A/C gets engine temp back to normal and surging issue goes away.
Less frequently, car’s RPM drops to nearly stalling and on a couple occasions the car actually stalled.
Symptoms began around 100,000 miles. Lastly, this happens ONLY when at idle (usually in gear) or when coming to a stop or driving slowly, like in a parking lot.
Corrective steps taken to date:
- Throttle body cleaned by dealer mechanic (I’m not 100% sure it was a thorough job.)
- Thermostat changed.
- A/C recharged.
- Belts & fans checked - OK.
- Engine computer reset (?) - battery disconnected by mechanic for 30+ minutes to “reset” computer (suggested in another forum.)
This has been going on for at least 3 years now. I’ve been to my Ford dealer and an independent mechanic’s shop numerous times for this. The dealer was never able to reproduce the problem. The other mechanic finally experienced the surging. Oddly enough, after each visit to the shop, the car seems fine for the day and then the symptoms begin to return in full force!
