Car stored for 5 months - what should I ask the mechanic to check?
Hello helpful folks!
Annually, I have to store my gas-powered 2019 Subaru Crosstrek car outside for 5 months (summer into fall). When I return I ask the mechanic (various folks over the last couple of years) to “check the car” and “make sure its road worthy for winter” after the 5 months sitting.
Every time I get asked: Oh you want it inspected?
And I don’t know what to say back. I usually stammer and say, yes, if that includes checking all the things that might be affected by a long sit in hot weather? If that includes ensuring it is fit for -40C winter driving…
Each mechanic also is vague. I think I don’t know the right way to ask for what I need.
This year, the mechanic did not check the tire inflation. I noticed it bulging quite bit and rechecked myself. It was at 18. Should have been 32.
Can anyone here help a lady understand what one should say? Is there a list of things I should ask to be checked? Is there standard terminology I should use?
All help gratefully received :slight_smile:
cc
5 months is nothing… Check the air pressure in your tires, engine oil, coolant and brake fluid levels, if all good just hop in it and drive…
I’m in the south, so rust and other rust belt problems is not a factor…
(post deleted by author)
Thanks. That’s helpful.. I have said “check all fluids” in the past. Is that part of an “inspection” normally?
I’ve stored vehicles and taken them out of storage for many years.
The first thing to do when storing a vehicle is add a fuel stabilizer in the gas tank and fill the tank.
I use this because it’s better than stabil.
When the car comes out of storage, all fluids are checked, tire pressures are checked, and the battery is checked,
OK. Thanks for that great tip. I have seen stabilizer used in stored outboard motors, but never thought to use it on the car over the 5 months. :sun_with_face:
You want to use Seafoam because if prevents phase separation of ethanol gas.
Good to know! Thank you!
