Hello, I had difficult in starting my car.
The ignition cranks and car is started, and run at reasonable time to get enough engine hot and power. Everything is fine like engine temp, coolant, battery level, fuel pump etc.
After engine off and I put on AC for just a mere 10 minutes with key at ignition switch position, then I try starting the engine it doesn’t go live. We then started by running start ie pushing or jump start.
Really surprise with a short period why would the car not start. Please help me. Thanks.
