The transfer case shift actuator is attached to the rear of the transfer case however the transfer case must be disassembled to disconnect the actuator shafts. This is an 11.5 job, not recommended for a shade tree mechanic.
What mode does it fail in? Truck is in 2wd. Actuator is broke. Ur stuck in 2wd? That’s bad?
