Camry rack & pinion dust boot
@bzb
Any decent parts store will stock the correct clamp . . . I’m talking about the big inner one, the one that needs to be crimped down with the special pliers
The inner clamp can’t be reused. You basically have to destroy it to remove it. The outer clamp, however, can usually be reused
A mechanic should only use a pickle fork on a tie rod end/ball joint that’s getting replaced
Good luck!
