Reading your column in the StarTribune, you Talked about oil circulation problem in Toyota engines (1997-2002), does this mean all 4 & 6 cylinders?
Thanks,
Frozen in Minnesota, Darrell C. Wistrom
The cartalk guys don’t post here, but we can help.
It means 4 and 6 cylinder engines in the Camry and Solara from 96 to 03.
Note that if you’re having this problem, you’ll probably have an easier path to getting it resolved now, as Toyota has already settled one class action lawsuit regarding the sludging.
