While the headlights are off -when I step on the brakes- the dash board lights dim, even the little light in the glove compartment.
All other lights in the cabin are fine and when I turn on the head lights everything is cool except the ABS light comes on. Seems to be messing with my odometer reading as well. HELP !!
Have your alternator/charging system and battery checked.
Thanks I’ll give that a shot.
First clean the battery and cable connections with a battery post cleaning brush. Also clean the ground wire connection between the battery and the chassis.
